Ultradog MN
- Location
- Twin Cities
I'm still not getting this pump to bleed properly and/or the lift arms to stop chattering.
They say if you aren't much of a mechanic keep changing parts till you find the problem.
I have had 3 different pumps on this tractor, including an NOS pump that I have. They all do the same thing.
I have had both ends of the suction line off, cleaned them with lacquor thinner and gooped them with silicone.
I have bled about 3 gallons of oil out of the pump - high speed, low speed.
I blew lacquer thinner through the suction line to possibly clean out the filter.
Getting frustrated here.
What should I do?
What should I do?
