TractorLinks.com
Order Ford 800 Parts Online
Re: model 800 hydraulics
Kurt-NEPA
11-08-2012 03:40:59
I'm with Old on this. Are you using Universal Tractor Fluid (UTF) in the hydraulic sump? It is thinner than 80/90 weight oil and does not thicken up so much in the winter.
My 8N has 90 weight oil in sump. In the winter, its slow as molasses. My 660 has UTF in the sump. Work just fine all year.
TONY JACOBS
11-08-2012 07:47:03
 Re: model 800 hydraulics in reply to Kurt-NEPA, 11-08-2012 03:40:59
Hello Kurt , I have been through this many times here on the board but not with you . 80 / 90 WEIGHT MINERAL OIL is the spec for 800'S OR 801'S also NOT GEAR OIL . Don't listen to the crap you will here about out dated oil specs , the oil made to the old specs is just as good as any other oil on the market when made by the large brand names like the ones I use , TEXAS REFINERY CORP. , MYSTIC BRANDS , KING OIL , VALVOLINE plus many others . Crap like WAL-MART and TRACTOR SUPPLY don't make the old spec oils because of limited sales THAT'S THE BOTTOM LINE MONEY , Same with crap from NEW HOLLAND it is a FITS ALL OIL they do not care if your old tractor lives or dies because it does help them sell more new tractors . If you are using 90 weight GEAR OIL in your 8N that is not correct , you should be using 90 weight MINERAL OIL and it will work fine all year round , that is the correct spec oil for the N's . UTF is too thin for those pumps and add to the fact 50-70 years of wear it makes it worst still . Any decent Parts supplier or Oil Supplier can get it very easy as Over The Road Class 8 Semi's still use it in their transmissions . Thanks Tony
