Yesterday's Tractor Co.
Shop Now View Cart
Order Ford 4000 Parts Online
Re: 4000, hyd system don't want to lift implement
11-07-2012 16:47:07
Start with the easy stuff. Is it full of fluid? Is it the right fluid and clean?
patricia bell
11-07-2012 16:49:43
 Re: 4000, hyd system don't want to lift implement in reply to Royse, 11-07-2012 16:47:07
Ok, failed to mention,yes, checked all fluid
and levels, all good,,,
11-08-2012 03:56:09
 Re: 4000, hyd system don't want to lift implement in reply to patricia bell, 11-07-2012 16:49:43
The transmission and rear end are separate reservoirs. The hydraulics draw fluid from the rear end. Many people check the transmission fluid level with the transmission dipstick, and think they"ve checked the rear end fluid level as well. Just in case this is your situation:
There are two small SQUARE HEADED fluid level check plugs on the right hand side of the trans and rear end.
As you are seated on the tractor, the transmission check plug is above your right toe.
The rear end check plug is behind your right heel. Difficult to see - you may have to squat down to see it.
These are small SQUARE HEADED pipe plugs. Pull them out and add fluid until it comes out of the hole.
