Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 800 Parts Online
Re: model 800 hydraulics
old
11-07-2012 12:24:17
#1 what fluid do you use?? #2 what fluid do you use in the rear end and transmission??? If you use a UTF or such hyd fluid in the hyds and a 80W-90 or such in the other 2 the seals between the rear and the trans could be bad and mixing fluid which will cause that problem because the hyd fluid becomes thick like to other 2 and then you have problems. I would drain all 3 and put in UTF in all 3 and if the problem goes away you know why
