TractorLinks.com
Order Ford 4000 Parts Online
Re: ford 4000 lift
jokester
11-06-2012 08:58:22
Brandon4000 said: (quoted from post at 17:33:57 11/06/12)
JMOR said: (quoted from post at 17:14:41 11/06/12)
Brandon4000 said: (quoted from post at 11:57:54 11/06/12) I have a ford 4000 that the lift will go up but wont come down. took seat and top plate off and replaced all orings on piston and piston housing, drained and replace oil, reassembled and as soon as i started tractor the lift went to the top and will not lower. what is a common issue, or what should I look for?
Real good chance that either the path from lift cylinder to dump port is clogged with trash or that Control Valve is not moving far enough out to open dump port (maybe simple linkage adjustment).
I assume that the valve is built into the housing that the piston goes in under the seat. if that is correct i could not get it to move while i was cleaning it. didnt force it cause i didnt know how it worked and didnt wanna break it
huh?
This post was edited by jokester at 09:00:45 11/06/12.
