Topic: Can This be Salvaged?
[Return to Forum]
| Author |
[Modern View]
| Tom Bond
11-05-2012 17:12:58
98.212.12.115
I got my POR15 kit and looked a little closer at what I thought was a minor leak. Found a couple corroded areas. Only one leaks slowly but these look like they might need something more than the POR15 sealant. Can something that looks this bad in a close up picture be repaired? Don't really want to waste the $70 kit on this if it won't seal it. Or is it time to start looking for another 801 tank? |
| rustyfarmall
11-07-2012 06:07:35
216.248.71.226
Re: Can This be Salvaged? in reply to Larry NCKS, 11-05-2012 17:12:58
| Just my opinion, but those gas tank repair kits should be used ONLY if a NEW or good USED tank cannot be found. In this case, NEW tanks are readily available. |
| sotxbill
11-07-2012 06:01:59
144.160.98.80
Re: Can This be Salvaged? in reply to Tom Bond, 11-05-2012 17:12:58
| | yes, por 15 will fix that and worse. I had to put duct tape on the outside to cover some pin holes before I used the por15 on several bad tankes. Its the most expensive and its considered the best. be sure to follow the steps with the acid and then wash and then dry, dry, dry, before useing the final por15 sealer. tank will then be good for another 100 years. I would then prime the outside and put about 6 coats of very good grey paint on the outside to make it last even longer. only thing wrong with por15 is that the acid wash will remove all paint.. and even if you seal the tank during treatment, it will still remove all the paint and thats not good if its a painted tank, so you must figure on repainting the outside if its a painted tank.
expensive, good and forever!! |
| Royse
11-06-2012 19:55:53
69.36.49.151
Re: Can This be Salvaged? in reply to Kirk-NJ, 11-05-2012 17:12:58
| Tom, as NoNewParts said, "You are the best judge, since you are there."
$70 is almost half the price of a new tank on this site, and I didn't look anywhere else.
See the link below.
That tank sets right over you engine and exhaust manifold.
I get kind of scared about those things, I'll admit that, but I let my
grandkids drive mine.
The kit could be used on something else.
Just my two cents.
Peace of mind |
| Ed H.-OH
11-06-2012 18:11:43
72.23.247.131
| Quart of fiberglass resin is about $20.00. Works great for repairing gas tanks. |
| NoNewParts
11-06-2012 03:45:25
67.240.145.25
| while I've fixed many tanks with JB, screws, etc,
these were usually on tractors with tanks not over the engine.
On Fords, I'm a little more fussy.
physical damage, maybe
rusting out, I usually junk them.
After sanding, I look at them and judge whether
I could hit the bottom with a hammer...or actually hit it a bit.
a good tank will easily take a hammer hit.
rusted thin ones won't.
You are the best judge, since you are there. If it worries you when
you are checking it out, replace it.
lots of gas and its weight, bad pothole, split tank.....not good |
| Tom Bond
11-05-2012 19:24:24
98.212.12.115
Re: Can This be Salvaged? in reply to Douglas Miner, 11-05-2012 17:12:58
| Ben, just curious. Did you clean it up and apply the JB Weld first, let it cure and then go thru all the steps? Marine Clean and Metal Ready. Or did you do the Marine Clean and Metal Ready before the JB Weld? |
| ben(tn)
11-06-2012 19:00:22
99.190.245.180
Re: Can This be Salvaged? in reply to Tom Bond, 11-05-2012 19:24:24
| first off i put some rocks in the tank and shook the crap out of it then used some c.l.r,and shook that around and washed it out and let it dry then went with the sealer according to the directions, in the mean time i cleaned an sanded the out side and beat on the outside to make sure i had all the rust out then applied a good coat of j. b to it like i said its been on my tractor for over 2 years an no problem lucky i guess |
| ben(tn)
11-05-2012 18:30:21
99.190.245.180
| my tank on the 8n was worse than that, cleaned it the best i could then used j.b.weld on it and sealed it with por 15 that was 2 years ago an it hasnt leaked yet |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
