Out bushhogging today, our 65 3000 gasser ran just fine...it liked working so much that it wouldn't shut off back in the barn. I pulled the ground cable at the battery post, figuring that would stop it - no dice. Finally shut it down with gas tap off & pulled the choke. I touched the ground cable back on the battery post and could hear some clicking (not the starter relay, as far as I could tell) and there was a crackly spark at the ground clamp as I touched it to the battery, so something was still hot. No, I didn't try to do that again - left it disconnected.
Went through the shop manual. Could it be the voltage regulator? It still has the generator. As near as I can tell, the voltage regulator appears to be the only possible path for a back feed to the ignition system. Do these Lucas/Prince of Darkness regulators have a failure mode like that? Of course, another possibility might be a shorted wired somewhere - all wiring is original. But before I go tearing into that original loom, thought I'd ask about these VRs.
Thanks!
(p.s. - I did cruise thru the archives first...found plenty of no-sparks/weak-sparks but nothing like this, with sparks that won't quit)
Thanks!
