TractorLinks.com
Show Parts for Model:
Re: dip stick
John in la
11-03-2012 13:34:36
We may both be right.
I looked around to find a answer. I noticed that your book is 1954 and mine is first run 1952 when the tractors first came out.
In 1952 at serial #18094 they changed the tube but left the stick and pan the same. It went from 10.47 inches long to 11.25 inches long. This in turn would raise the stick 0.78 inches.
So more oil would be needed to read full on the stick. I wonder if .78 inches works out to one quart.
Ford may have found out 5 qts was not cutting it and changed it to 6 qts.
The question I now have is why the 600 to 801 manual says 5 qts but I am not able to access that info right now.
Like Dean my 801 is suppose to hold 5 qts but I believe 5.5 is more about right.
Dean
11-03-2012 17:09:34
 Re: dip stick in reply to John in la, 11-03-2012 13:34:36
Bottom line is that engine oil level is not an exact science nor need it be. The "operating range" crosshatch encompasses about a quart.
Dean
John in La
11-03-2012 17:20:44
 Re: dip stick in reply to Dean, 11-03-2012 17:09:34
Yes as long as you have enough oil in it that it keeps the inlet covered while using the tractor; and not so much as the crank hits it you are in the right range.
