Yesterday's Tractor Co.
Shop Now View Cart
Order Ford 640 Parts Online
Re: 640 carb kit
11-02-2012 17:53:11
Thanks Old and Soundguy. I did try all you said except for the hand off and on the air intake while running. i'll check with O'rieley's and napa for a kit and give it a try. They sell the new Zenith if the rebuild goes afoul. All my auto carb rebuilds went to the scrap pile and bought a new or rebuilt carb but this TSX-580 doesn't look too complicated providing the internals aren't all pitted up where new parts go.
11-03-2012 08:44:54
 Re: 640 carb kit in reply to gargriff49, 11-02-2012 17:53:11
The tractor carbs are very simple and so simple that people make them hard. You do need a bucket of carb cleaner to soak the carb in for 24 hours or so compressed air to blow it out a couple cans of spray carb cleaner and a small wire or what I use it a torch tip cleaner tool to poke into the passage ways to make sure all are open as the need to be. The Walker kits have good instruction and a picture of all the parts
11-02-2012 18:02:44
post back.
11-13-2012 18:24:34
 Re: 640 carb kit in reply to soundguy, 11-02-2012 18:02:44
Basic carb rebuild kit from YT seemed to do the trick.Soaked the disassembled carb in pine-sol for 4 days then hot water bath, blow dry and reassembled.New fuel line and shut-off and new 1 wire alternator to finish up the 12v conversion. Going to tackle the PTO seal now so i don"t have to keep a drip pan under the Diffy. None of the parts stores in my area of SW Mo. had a kit that said it was for a TSX-580 carb. It showed for 4 or 5 TSX models but not the 580.
11-14-2012 05:03:58
 Re: 640 carb kit in reply to gargriff49, 11-13-2012 18:24:34
good to hear.
remember to draint he hyds and diffy before pulling pto shaft... and be carefull dstabbing it back in to not damage the inter sump seal.
