| Ford Tractors Discussion Forum |
Topic: NAA front wheel wobble
[Return to Forum]
| Author |
[Modern View]
| 5000 Dave
11-01-2012 09:49:27
69.95.14.17
Front wheels wobble going in forth gear. what it the best fix for this? |
| Ultradog MN
11-01-2012 17:39:22
184.100.104.240
Re: NAA front wheel wobble in reply to 5000 Dave, 11-01-2012 09:49:27
| Drive in 3rd. And be glad you don't have a Sherman Overdrive. You can Check the toe in on the tractor. The manual calls for a difference when you measure between the front and rear of your steering tires. It should be toed in I'm guessing 1/4" to 3/8" - others here can tell you the exact #. Tow out will make them wobble and wander. If you are cheap and don't drive the tractor on pavement much you can fudge on that dimension and go more toe in. Wont hurt nothing when you are in dirt or woods. I had a couple of 8Ns that were a bit loose. I rode them in Sherman Over with a wrench in my pocket and kept tweeking the toe in till they didn't wobble. EZ. |
| GLC
11-01-2012 17:24:45
141.152.249.197
| Tire rod ends, steering box play, wheel bearings, toe in are likely causes.
Outside chance that it might also be the center axle pivot pin. Mine was shot! I had to tear it all apart and had a good welder I know build up around the pivot pin housing which connects the axle to the engine. I then could snugly fit a new pivot pin into the assembly and it tightened everything up nicely. That and some new tie rod ends and no more shimmy. |
| Jimmyjack
11-01-2012 14:29:48
216.105.208.2
| Kurt-NEPA
11-01-2012 13:52:10
70.44.245.96
| Check the toe-in. A toe out can cause a shimmy. Try adjusting it a bit - should be 1/4" toe in, but I find it hard to measure. |
| soundguy
11-01-2012 12:05:10
184.233.8.31
| | put your feet ont he ends of the draglins next time it wobbles... if it straightens up.. hubs are liekly ok, and it may be tie/drg ends.. or steering box. pull over and grab the draglinks and move fore / aft and see what's loose. ends are replaceable. hub loose may mena bearings, if it ain't wallowed out yet. steering backlash or play might be adjusted out.. might have to refurb box ( not a big deal ) post back |
| Fordfarmer
11-01-2012 11:07:52
98.125.120.207
| The hubs wobble on the spindle, or the wheels wobble like your'e turning the steering wheel back and forth a bit? My uncle's 8N had loose drag link ends that let it wobble like the steering wheel was being turned... new drag link ends cured that. Could also be play in the steering box. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
