Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: steering box question 641
kentrx1
10-31-2012 09:29:11
wouldn't spindle wear cause it to be hard to steer in either direction? this is only hard to turn in one direction...fine in the other. in your reply you said after removing dash top then the "vred". not quite sure what you mean by that. thanks for all the help!
soundguy
10-31-2012 11:34:43
 Re: steering box question 641 in reply to kentrx1, 10-31-2012 09:29:11
voltage regulator
the spindle bushing wear would lilkely make it hard to turn in either direction.
my point was if you are doing hte box.. you might as well check all areas int he steering system. no sense in fixing one part to only have an issue with another.. thus address all together..
kentrx1
10-31-2012 12:23:03
 Re: steering box question 641 in reply to soundguy, 10-31-2012 11:34:43
thanks for all your help!
kentrx1
11-04-2012 13:45:01
 Re: steering box question 641 in reply to kentrx1, 10-31-2012 12:23:03
do you have to cut the top bearing cup off the steering shaft? i have tried everything else so far and it seems bonded! also, how do you get the side plates off the steering box? removed the 2 bolts holding them and tried tapping on the edges and they did not budge. decided to call it a day and beg for expert help!
thanks
Copyright © 1997-2015 Yesterday's Tractor Co.
