TractorLinks.com
Order Ford NAA Parts Online
Re: NAA serial number
Sean in PA
10-31-2012 04:10:38
According to John Smith's site, the serial number on the early NAA's was on the left side of the engine near the front, just below the head and above the generator, but once they moved the serial number to the transmission they no longer put them on the engine. Engines and transmissions have been swapped over the years so some might have an early engine and a late transmission and therefore have 2 different serial numbers, and some might have a later engine and an earlier transmission and therefore have no serial numbers.
There may have been more characters at the beginning that are worn off or no longer readable, and NAA114159 would be a valid 1954 serial number.
It also might be a transmission from a later hundred series that was transplanted. Is there another number above the one you posted?
Fordfarmer
10-31-2012 06:35:14
 Re: NAA serial number in reply to Sean in PA, 10-31-2012 04:10:38
Actually, the transmission from a hundred series won't work on a Jubilee/NAA, because of the difference in hydraulic lines.
upnorthwi
10-31-2012 06:21:53
No, there"s no number above it.
My impression by pictures I"ve seen is "NAA" should be before the number. Did they Possibly not put NAA with all serial numbers?
I"ll have to check again on the motor.
