Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Hydraulic pump on 700
Kurt-NEPA
10-30-2012 10:29:40
You probably have a piston pump, The overhaul kit does not include, the wobble shaft, main bearing cup and cone, and the needle bearing.
It depends on what's wrong with your pump. If its bad check balls, springs, or seats, then the kit will be all you need.
If your pump is loosing its prime, then its likely the wobble shaft and seal. Its a common cause of failure on these piston pumps. As time goes by, the seal wears a groove in the wobble shaft and necessitates replacement of both. A new wobble shaft requires a new main bearing, and you usually damage the needle bearing getting the seal and main bearing cup out. So I would figure on replacing all of them.
