TractorLinks.com
Show Parts for Model:
Re: Hydraulic pump on 700
old
10-30-2012 09:13:37
Geo a 700 most likely has the piston type pump not to old vane pump that was used on the Jubilee and the NAA.
George Marsh
10-30-2012 09:23:45
 Re: Hydraulic pump on 700 in reply to old, 10-30-2012 09:13:37
I know, the person on YT has made an adaptor kit to up grade to a modern after market hydraulic pump, not a ford piston or vane pump.
old
10-30-2012 10:38:37
 Re: Hydraulic pump on 700 in reply to George Marsh, 10-30-2012 09:23:45
Shoot if your going to get to that point is it easier to just use a front mount crank drive hyd pump like used on loaders and be do with it
soundguy
10-30-2012 14:50:45
 Re: Hydraulic pump on 700 in reply to old, 10-30-2012 10:38:37
that's be an interesting setup on a rowcrop....
old
10-30-2012 18:28:55
 Re: Hydraulic pump on 700 in reply to soundguy, 10-30-2012 14:50:45
Plus if set up right you have the option for pretty much as many remotes as you have control body levers
soundguy
10-31-2012 05:22:40
 Re: Hydraulic pump on 700 in reply to old, 10-30-2012 18:28:55
except.. you couldn't use a standard front pump on a rowcrop. bolster is in the way...
old
10-31-2012 08:41:03
 Re: Hydraulic pump on 700 in reply to soundguy, 10-31-2012 05:22:40
Isn't there an option or some such thing so as to be able to install a loader with a crank shaft driven pump on them?? And how about the hand crank handle hole or do they not have that as an option for starting as the say 801 series have
soundguy
10-31-2012 09:13:35
 Re: Hydraulic pump on 700 in reply to old, 10-31-2012 08:41:03
here's the front bolster on my 740
difficult to hand crank or front pump them.
That's why i said it would be interesting to see a stinger pump on a rowcrop. :)
old
10-31-2012 09:18:50
 Re: Hydraulic pump on 700 in reply to soundguy, 10-31-2012 09:13:35
In all the years I have messed with tractors I have had only 1 Ford Rowcrop so was not sure and that one I had less then a month. Had a 981 got it in got it running and sold it as fast as I could I hate those SOS tractors
George Marsh
10-30-2012 12:03:18
Old,
Kurt-NEPA knew who I was talking about. TOH made the adapter Kit. I wouldn't want a pump in front of the tractor. My luck, I would run in to something and break it. Also would need to adapt hyd lines too. I like what TOH is doing and will use his kit when my pump goes bad.
George
old
10-30-2012 12:22:54
 Re: Hydraulic pump on 700 in reply to George Marsh, 10-30-2012 12:03:18
Well again if I have a front pump you have a mount and a brush guard as par of the mount. Ya just a pump sitting out in front is not good since it would be bait for every stick etc you could hit
