TractorLinks.com
Show Parts for Model:
Re: SOS ORC Adjustment
Larry NCKS
10-30-2012 00:08:49
1. What manual do you have? The original Ford shop manual on these tractors had the ORC transmission in it. You needed the transmission supplement manual for the DDC. Either or both these manuals are usually available at reasonable prices on eBay.
2. Are you saying the transmission was stalling the engine until it got warmed up when in 4th gear? If so, band adjustment might be in order. It is certainly in order if you've adjusted them using the DDC specs. It might also be sticky control valves. I have new control valve bodies on hand for this transmission.
3. I'm guessing you're saying R2 operated, but that there seemed to be no difference in speeds between R2 & R1? If so, then Chris' scenario may apply, if all forward ratios, 1 through 8 operate normally.
