Yesterday's Tractor Co. The Right Parts, Right Away
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: ford 4500 tlb no start
[Return to Forum]
Notsofastfreddie
10-29-2012 18:23:21
65.101.217.59
I have a 1969 Ford TLB that will not start, even with ether. Replaced fuel filter, primed but no fire. Jumped battery with diesel truck, and used ether but still no fire. Checked shutoff cable on pump, is against stop. Tractor has been sitting about a year. Did not run well then. I'm stumped. Any suggestions would be appreciated. Thanks, Fred
[Reply]   [No Email]
Notsofastfreddie
10-31-2012 13:46:49
161.215.18.51
 Re: ford 4500 tlb no start in reply to Notsofastfreddie, 10-29-2012 18:23:21
Thanks, Ultradog. Will try taking the cover off next week. Is there anything I have to worry about flying off when the cover comes off? That seems to make the most sense, considering no reaction to numerous ether shots. Fred
[Reply]  [No Email]
RodInNs
11-01-2012 08:58:54
216.118.158.123
 Re: ford 4500 tlb no start in reply to Notsofastfreddie, 10-31-2012 13:46:49
If you can't make that engine RUN on ether you have far more serious problems than the pump. Freeing the metering valve is not a big deal if it will fire on ether...
Rod
[Reply]  [No Email]
Ultradog MN
10-30-2012 08:28:24
184.100.104.240
I am not so good with injector pumps so others here will correct me if I get some of the terminology wrong.
If you open the top cover on the pump you will see the shut off shaft #4 moves the shut off bar #3.
The shut off bar in turn moves the metering valve #10.
Twice now on two different pumps the metering valve was stuck. I had to open the top cover and free it up. It is all very delicate in there so you want to tread lightly.
Once the pump had only been sitting for a year and another time it had sat for many years.
Both times I was able to open the cover and free up the metering valve and the tractor started right up after that.
[Reply]  [No Email]
Notsofastfreddie
10-30-2012 06:38:30
65.101.217.59
Thanks Jim. Not to rub it in, but it was 70 degrees here in CO yesterday. There is very little fuel squirting out at the injector lines. With the truck tied to the battery, it seems to be spinning ok. What I don't get is that spraying ether directly into the manifold does not get any reaction, violent or otherwise. Hate to spend $$ on a new pump when the engine is shot. Last time it ran had lots of blowby and low power. Fred
[Reply]  [No Email]
RodInNS
10-30-2012 08:26:28
68.171.231.80
 Re: ford 4500 tlb no start in reply to Notsofastfreddie, 10-30-2012 06:38:30
How much blow did you give it? I'd try some more...mabey a 2-3 second shot while cranking aand see if it stumbles some. If it doesn't, try some more. If it won't try on a steady shot while cranking for 5-10 seconds then I'd say you have no compression
Rod
[Reply]  [No Email]
JF in CT
10-30-2012 05:48:07
70.194.7.103
I would unscrew the fuel fittings at the injectors, open the throttle wide and crank it to see if you are getting fuel. Is it cranking fast enough? Is the thermostart injector working? Mine won't start without it in cooler weather.
Jim
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
