| Ford Tractors Discussion Forum |
Topic: Re: 6610 turbo
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| RodInNS
10-29-2012 15:53:48
68.171.231.84
You could...but.... The turbo engine has oil cooled pistons, keystone rings, different valves and seats, larger injectors, nitrided crank and an oil cooler. As long as you don't go crazy on the fuel screw it should be ok....Rod |
[Reply] [No Email] | |
| Bern
10-29-2012 16:25:00
66.218.203.131
Re: 6610 turbo in reply to RodInNS, 10-29-2012 15:53:48
| I think his biggest problem would be keeping it cool. Let me re-state that. Keeping it cool would be his most immediate problem. Engine and driveline component longevity would be a longer term issue. I could see it cracking pistons within 1000 hours. A lot would depend of course on how hard it's used. |
| RodInNS
10-29-2012 17:15:56
68.171.231.84
Re: 6610 turbo in reply to Bern, 10-29-2012 16:25:00
| | Yes, cooling could be a problem. Driveline... Is pretty much the same on a 66 and 76. I would dare say if he set it on a dyno for 85 or so... It should be fine. My 77 is running around 105 for the past 3000 hours and is at 8000 total hours, original other than two head gaskets... I know of one that's probably close to 120... And he's broken some rings. I know the compression ratio is a bit lower on the turbo pistons but shouldn't be a big factor if he doesn't go too far.... I know... Famous last words. Rod |
| Bern
10-29-2012 18:10:17
66.218.203.131
Re: 6610 turbo in reply to RodInNS, 10-29-2012 17:15:56
| | Piston life would defintely be a concern since they are not oil cooled, not to mention the difference in compression ratio. I've seen factory stock 7610s crack pistons, not turned up, just worked hard all its life. Clutch is lighter on the 6610 (12" vs 13"), and the finals are as well (2 speed vs single speed PTO). On the older 7000s and 7600s, the transmission gears and bearings were different as well. If it was set to 85, I would agree, it would likely be fine, cooling aside. |
| RodInNS
10-30-2012 06:03:08
68.171.231.82
Re: 6610 turbo in reply to Bern, 10-29-2012 18:10:17
| I can't say for certain...but I think the rear ends and transmissions used the same components at least in the latter part of the 10 series. I know for certain that all had the same 13"clutch after 10/85 or some date around there. I know you're corect that the older series tractors did use heavier components on the 7xxxx tho. As far as cracked pistons.... I'd have to wonder if some of that isn't due to a bit too much ether...Rod |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
