Fuel Tank Sealer
Tom Bond
After I dry fit my replacement tank, just for the heck of it before I painted it, I poured in a gallon of gas in to check for leaks. Sure enough, there's one leak where it looks like someone put too long a mounting bolt through the cage nut on the rear support. Over time, It looks like it eroded away from the inside where it dimpled. Leaks a pretty steady drip. Will POR-15 stop something like this or is it time to start shopping for another 801 tank? Any suggestions or other products that might do the job?
Sure will! I actually had a leak on a tank that the Por 15 driped out of. A little time of chasing Por 15 back and forth and it hasn't leak a bit since (5 years)
Hello, Fiberglass resin works great, Don"t make any heat or sparks cleaning it.Buy it in any auto parts store. -ed
