TractorLinks.com
Show Parts for Model:
Fuel Tank Sealer
Tom Bond
10-25-2012 18:19:42
After I dry fit my replacement tank, just for the heck of it before I painted it, I poured in a gallon of gas in to check for leaks. Sure enough, there's one leak where it looks like someone put too long a mounting bolt through the cage nut on the rear support. Over time, It looks like it eroded away from the inside where it dimpled. Leaks a pretty steady drip. Will POR-15 stop something like this or is it time to start shopping for another 801 tank? Any suggestions or other products that might do the job?
Fuel leak
10-26-2012 17:58:18
 Re: Fuel Tank Sealer in reply to Tom Bond, 10-25-2012 18:19:42
You could use an epoxy like JB weld. Clean it really good and let it dry for 24 hours.
36 coupe
10-26-2012 16:48:15
I favor solder with a electric iron.Get it clean and solder Use Nokorode solder paste.
Ed H.-OH
10-26-2012 13:03:16
Hello, Fiberglass resin works great, Don"t make any heat or sparks cleaning it.Buy it in any auto parts store. -ed
Jim in Ma.
10-26-2012 05:23:21
I would just clean and solder it with an iron.
Easy 10 min fix.
woodbutcher
10-26-2012 04:09:12
Tom,
I used Red Kote on my 4000. It worked well.
Butch
GlenIdaho
10-25-2012 20:20:42
Check the link below concerning POR 15 tank sealer. I used it in my take, no problems.
WayneIA
10-25-2012 18:44:21
Sure will! I actually had a leak on a tank that the Por 15 driped out of. A little time of chasing Por 15 back and forth and it hasn't leak a bit since (5 years)
