Yesterday's Tractor Co. Same-Day Parts Shipping Available
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 3550 oil check.
[Return to Forum]
pete hall
10-25-2012 16:47:37
184.10.228.224
Sorry but Im lost as to where to check the hyd oil level on my 3550 industrial.Is the rear end and hyd.lift ams resivour connected? im a ford man but this has me embarrased!
Thanks in advance for helping.
pete
[Reply]   [No Email]
Sean in PA
10-25-2012 17:01:06
71.224.102.32
Yes, the rear axle center housing where the differential is located is also the sump for the hydraulics for the 3 point lift system. The fill hole is on top of the center housing under where your right butt cheek is when you're sitting on the tractor. The level check hole is on the right side of the center housing, near where you right heel is when you're sitting on the tractor. There are 2 filters, the first one is a screen on the pickup line that is meant to be cleaned and re-used, and the second one is a cartridge type filter on the return line that is meant to be replaced. Both filters are located inside the rear end, and you need to pull the top cover off to replace them. They don't have to be done every time you change the fluid, but if you don't know the history of the tractor it's best to service them the first time you change the fluid so you have a known good starting point.
If you have a front end loader, it is most likely powered by a separate hydraulic pump that is mounted to the front of the tractor and runs off of a shaft that goes to the crankshaft pulley, and it would have it's own reservoir as well, most likely the frame of the loader is the reservoir. Follow the hoses from the loader control valve to see where they go to be sure.
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
