TractorLinks.com
Order Ford 881 Parts Online
Re: Ford 881 with Wagner loader quit working?
sotxbill
10-25-2012 14:25:31
Shaft on pump is worn out and slipping. change all the fittings on the shaft, front and rear that show any wear as its nearly impossible to get to.
Also install new belts on the loader at this time!
Dale John Swineheart
10-26-2012 15:40:24
 Re: Ford 881 with Wagner loader quit working? in reply to sotxbill, 10-25-2012 14:25:31
Bill, the shaft is not spinning. Like you guessed, the splines on the shaft are probably bad. Can I order new shafts/splines? I got it into the garage tonight and will tear it apart tomorrow. I have no loader at all now. Dale
old
10-26-2012 15:55:28
 Re: Ford 881 with Wagner loader quit working? in reply to Dale John Swineheart, 10-26-2012 15:40:24
Replace both the shaft and hub at the same time.Reason I say that is the hub the shaft slips into wears at the same time the shaft does so if you only replace the shaft the hub will eat the new shaft and it will not last very long and it is not a fun job to have to do twice
