Yesterday's Tractor Co.
Shop Now View Cart
Order Ford 881 Parts Online
Re: Ford 881 with Wagner loader quit working?
Dale Swineheart,
10-25-2012 09:58:51
I am pretty sure it was full of oil. There is a filler cap on the loader arm that is close to the front right engine. It said to fill it up close to the top vent cap. There was no oil leaking or broken hose, must be my spline shaft if bad. I will take it off tonight for further review. Thanks, Dale
10-25-2012 10:37:59
 Re: Ford 881 with Wagner loader quit working? in reply to Dale Swineheart,, 10-25-2012 09:58:51
As I said start it up lift the loader as far as it will and if the engine does not labor you will probably hear a rattle sort of sound which says the splines are striped out. BTDT to many times over the years and just did one that the loader front mount broke and the loader fell and snapped off the coupler
Dale John Swineheart
10-28-2012 08:35:22
 Re: Ford 881 with Wagner loader quit working? in reply to old, 10-25-2012 10:37:59
Mr. Old man, the spline shaft was wore down to the nub. I went to the New Holland dealer to see if they could order me another one. The spline bracket that bolts to the motor side was almost perfectly round inside. I need to order or make another one along with new shaft. are there aftermarket places to get these old parts? You hit it right onthe head. It was a pain in the rear to get to, but should work when I am done. Do you fill the loader through the vent cap up on the top right arm? There is a large cap by my right foot, but oil pours out when you loosen that cap. Dale Earnhardt Swineheart
10-28-2012 08:58:09
 Re: Ford 881 with Wagner loader quit working? in reply to Dale John Swineheart, 10-28-2012 08:35:22
This site as will the New Holland dealer of Vaul-bilt all should have bot the crank shaft hub and the spline shaft. I have learned over the years to replace both or have trouble soon after. As for the hyd oil ALL cylinders closed and yes fill till almost to the top in that vent cap. If you fill it to full oil will seep out that vent cap which does not hurt any thing other then making a mess
