Yesterday's Tractor Co.
Shop Now View Cart
Order Ford 881 Parts Online
Re: Ford 881 with Wagner loader quit working?
10-25-2012 09:13:05
as old said.
does it have oil?
is the pump actually turning with the drive shaft?
pump cracked / lines split?
if pump is turing, shut down and take input line to vlve off and aim in bucket and see if pump is making flow.
if yes, shut down and hook back up..
take the return to tank line off and ai'm into bucket and start tractor.. now try to lift loader. oil should be diverted to the lift cyl, and not have oil bypassing the valve or relief .. if you get oil inthe bucket.. either relief is stuck or spool is bypassing.
post back more details.
Dale John Swineheart
10-28-2012 08:39:12
 Re: Ford 881 with Wagner loader quit working? in reply to soundguy, 10-25-2012 09:13:05
Soundguy, the spline shaft was completely wore out. I took it to the New Holland dealer to see if they make an aftermarket part. the engine side bracket was bad along with the shaft. How do I check for proper oil level? Through the vent cap on the high part of the loader bracket? it has a large cap down low by my right foot, but oil pours out when you take it off. Dale
10-29-2012 05:30:13
 Re: Ford 881 with Wagner loader quit working? in reply to Dale John Swineheart, 10-28-2012 08:39:12
if it has a fill and drain.. just make sure it is full. 'stick the tank' so to speak.. etc.
