TractorLinks.com
Order Ford 600 Parts Online
oil pump replacement D1NL6600A retro fit on 641
rstokes2
10-25-2012 08:38:37
i have this pump on my 1960 641 info shows this to be 100 psi pump oil pressure should be @45-50 down the line this pump was installed.dont want to change any oil lines or oil gauge will this hurt motor old pump is shot. doing motor rebuild.
Scott Pa
10-25-2012 17:15:00
 Re: oil pump replacement D1NL6600A retro fit on 641 in reply to rstokes2, 10-25-2012 08:38:37
You also change the industrial engine relief valve spring that comes with the pump with the farm tractor spring for the correct pressure, sometimes the spring retainer cap gets damaged changing the spring so you may want a new one, both the pickup tube w/ screen and the outlet tube need replaced and remove the screen from you old drain plug instead of buying a new plug, while it is apart change the hex pump drive shaft.
soundguy
10-25-2012 10:59:26
according to the parts listing.. the rotor pump was 61-64 and:
D1NL6600A HYDRAULIC PUMP Pump Assy., Oil, L/Screen & Cover, This part is a direct replacement for C3NN6621B, When Replacing C3NN6621A, Also Use (1) D1NL6622A Cover & Inlet Tube and (1) B9NN6730A Plug, When replacing Gear Type Pump W/
pretty standard...
