run away throttle on a Ford 601 diesel
lemroy
On my 601 Ford diesel the throttle is wide open when first cranked. After a while it will slow down. How do I fix it? Roy
Replace the "plastic" governor ring inside the pump. That obviously requires pump disassembly.
x2 and while you're at it, clean all the debris from the old one out the return line and other places. Put new seals on the drive shaft too. pump kits can be had for 30 bucks on eBay and perhaps not much more than that at your l;ocal diesel shop.
NOTE: This is not a job you should tackle unless you know what you're doing!
