how to change input seal on 641
rstokes2
New User
how do you change inpui seal. take off four bolts and replace seal or is there any other problems do i get into
yes tanny seal im changing clutch anl ooked on forum and all said to replace tranny input shaft seal while your in there
Yes replace the seal while you have the tractor split for the clutch.
As Soundguy said - 4 bolts and pull the nose cone out. EZ.
I don't remember if you have to remove the clutch shaft and fork to get the nose cone out. Others here can say for sure.
