TractorLinks.com
Show Parts for Model:
Re: 850 clutch pedal pivot
awhtx
10-22-2012 18:35:20
There is a large nut (15/16" IIRC) inside the transmission case that pulls the pivot pin up tight against the housing. You will need to remove the shifter and top cover to gain access to the nut. You may need to buy a cheap Chinese wrench at a pawn shop and heat & bend it in order to get at that nut.
Ed Hotaling
10-27-2012 18:15:52
 Re: 850 clutch pedal pivot in reply to awhtx, 10-22-2012 18:35:20
Thanks for the tip. I was able to hold the nut with an adjustable wrench and turn the pin from the outside with ChannelLocks. It seems to be holding nicely.
