TractorLinks.com
Order Ford 960 Parts Online
Re: 1960 641 134 ci priming oil system after rebuild
jackleg
10-22-2012 13:53:18
It"s in the archives somewhere. But, basically what I"ve done is put I beleive it"s a 7mm socket or something close to that on an extension on connect it up to the oild pump allen shaft through the distributor hole; hook that a drill and pump away until the oil filter fills up then you can turn the motor with the starter while you"re drilling away and it will lube the entire system.
6t6cuda
10-23-2012 13:59:41
 Re: 1960 641 134 ci priming oil system after rebuild in reply to jackleg, 10-22-2012 13:53:18
when using the drill method (or the pressure tank) also slowly crank the engine over by hand until the rockers start to get oil, there is a cross hole in the cam that only lines up at one angle find that and then run the drill for a bit...
