TractorLinks.com
Show Parts for Model:
Re: ford 900 hydraulic ram arm broken..?
triplejfarm
10-22-2012 12:45:26
would overload be what caused the arm to split..? or just old age and wear and tear, and is there anything else that typicaly would be damaged, other than the things you listed, and where is a good place to get that manual ?
thanks so much... its the blind leading the blind here, :)
Deb
Dean
10-22-2012 13:02:42
 Re: ford 900 hydraulic ram arm broken..? in reply to triplejfarm, 10-22-2012 12:45:26
Shock loading, e.g., bouncing along over rough terrain with a lifted heavy load, is the most likely cause of damage, though there are other potential causes.
The FO-20 manual is readily available on the internet, probably including this site.
I always completely rebuild and readjust the lift cover anytime that it is removed. Procedures for doing so are in the manual.
Dean
triplejfarm
10-22-2012 13:19:22
 Re: ford 900 hydraulic ram arm broken..? in reply to Dean, 10-22-2012 13:02:42
ok thank you... will get that manual and try to get the cover off and take a better look... :)
thanks again
Deb
