Yesterday's Tractor Co. Compare our Prices For Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: ford 900 hydraulic ram arm broken..?
[Return to Forum]
triplejfarm
10-22-2012 12:13:00
198.109.220.253
3 point hitch quit working, opened the hydraulic fluid lid and can see a piece of metal laying in the bottom that looks like it is a gear and has splines, I am assuming from looking at part diagrams that its the hydraulic ram arm.. it looks like it split in half, its definatly round and has a shaft that slides thru it as I can see the spline grooves in it...does anyone have any documents on how to replace this...? thanks for any help at all.
Deb
[Reply]   [No Email]
soundguy
10-23-2012 05:26:43
107.41.221.7
 Re: ford 900 hydraulic ram arm broken..? in reply to triplejfarm, 10-22-2012 12:13:00
when you get the cover off.. take some pics.. especially of the shear face of the metal shaft.
check other associated parts like lift pins, nad lift arms, upper and loawer. that much of a shock load may have damaged other parts too.. dogbone.. piston.. cyl mouth..e tc..
[Reply]  [No Email]
triplejfarm
10-23-2012 05:40:08
198.109.220.253
 Re: ford 900 hydraulic ram arm broken..? in reply to soundguy, 10-23-2012 05:26:43
ok will do, thanks.....
[Reply]  [No Email]
Dean
10-22-2012 12:39:47
152.216.3.5
Since the ram arm is split, replacement is straight forward once the upper lift arms have been removed, which may require heat, and the lift cover has been removed.
Be sure to replace the cam follower pin, lift cylinder O-ring and back-up washer, and rock shaft bushings while the lift cover is off. I would also flip the rock shaft end for end.
Purchase of an I & T FO-20 manual before starting is advised.
Dean
[Reply]  [No Email]
triplejfarm
10-22-2012 12:45:26
198.109.220.253
 Re: ford 900 hydraulic ram arm broken..? in reply to Dean, 10-22-2012 12:39:47
would overload be what caused the arm to split..? or just old age and wear and tear, and is there anything else that typicaly would be damaged, other than the things you listed, and where is a good place to get that manual ?
thanks so much... its the blind leading the blind here, :)
Deb
[Reply]  [No Email]
Dean
10-22-2012 13:02:42
152.216.3.5
 Re: ford 900 hydraulic ram arm broken..? in reply to triplejfarm, 10-22-2012 12:45:26
Shock loading, e.g., bouncing along over rough terrain with a lifted heavy load, is the most likely cause of damage, though there are other potential causes.
The FO-20 manual is readily available on the internet, probably including this site.
I always completely rebuild and readjust the lift cover anytime that it is removed. Procedures for doing so are in the manual.
Dean
[Reply]  [No Email]
triplejfarm
10-22-2012 13:19:22
198.109.220.253
 Re: ford 900 hydraulic ram arm broken..? in reply to Dean, 10-22-2012 13:02:42
ok thank you... will get that manual and try to get the cover off and take a better look... :)
thanks again
Deb
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
