Topic: Re: 801 hydraulic problem
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| Kurt-NEPA
10-22-2012 04:58:06
70.44.245.96
As Larry Said, Multiple possibilities here. Time to do some diagnostics.
Question, once the tractor cooled, is the lift working?
Three easy checks to make.
1. Make sure the Draft/Position control lever is in the Position control (horizontal) position.
2. Pull the round plate on the left side of the tractor. The one with the hydraulic dip stick. Start the tractor. Look inside with a flash light and mirror. Do you see any leaks near the cylinder opening. If you can lift, hold up some weight and turn the tractor off and check again.
3. Loosen the pipe plug on the hydraulic pump (just a little) and start the tractor. Do you see any bubbles? (Caution - gets messy, get a catch pan and rags). You may have to loosed the plug a bit more until you see oil, but don't remove it, If you do, you'll need many more rags. If you see bubbles, let them clear, then tighten he plug and check the lift.
These two step can identify the two most common problems. Blown piston O-ring and Piston pump seal leaks.
A third possibility is a broken cam follower pin or broken linkage. Checking that out involves removing the top cover.
Seem strange the lift would stop "all of a sudden" was it normal before it failed. Piston O-Ring and pump seal problems usually come on gradually. A broken cam follower pin would happen all of a sudden - This is my guess here.
Post Back |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
