oil pressure line
If you are talking about the oil pressure line to the pressure gauge, then it connects to the block behind the hydraulic pump. Kinda hard to see with the pump in place.
yep.. look for a lil elbow with a 1/8" cap line behinf the gear drive portion of the engine mounted hyd pump on the right rear of the engine, as Kurt mentioned.
DO YOU HAVE TO TAKE OFF THE HYD PUMP TO FIND THE MOTOR OIL PORT? AND IS THE FITTING SOMETHING SPECIAL.
Wilber, here's a picture of the oil line running in behind the pump on my old NAA.
Behind the red coil wire.
You can find it without taking the pump off, but it is hard to work on with the pump in the way.
PS, please turn the caps lock off. Its hard for me to read that way.
the pump does not have to come off to find it.. you will almost assuredly have to take it off if you have to do much, other than unioninga line to a stub or something.
not to especially difficult..
