TractorLinks.com
Order Ford 3000 Parts Online
Re: ford 3000 clutch release lever
Ultradog MN
10-20-2012 16:38:49
Mark, you are correct the first photo I posted is a 6 sp non live pto.
I'm curious...
Did you remember my junk or were you able to tell from the pic? If so tell why please.
The photo below is a 3600 with lpto. You can see the arm/bell crank is different. Both however are welded onto the shaft.
Kermit, can you post a photo of it?
If the arm was welded onto the shaft then it surely can be rewelded if broken.
Check Break offered good advice too below. Make one.
Fordfarmer
10-21-2012 00:26:28
 Re: ford 3000 clutch release lever in reply to Ultradog MN, 10-20-2012 16:38:49
I saw the tractor dolly, so I figured it was a close-up of the 2000 you're working on. (should try to talk my uncle into buying it... good trade up from his 8N) One of the 3000's I had used the arm with the setscrew, can't remember about the other one. The arm on my 4600's clutch (independant PTO)is similar, but not identical to these... and is cast steel.
kermit vetter
10-20-2012 18:23:30
I wished I could send you a pic. of it. This is a 1965 3000, 8 sp trans with LPTO. On your pic. you see the protrusion in front of the clutch lever that serves as a stop. The lever has an adjustment screw that is adjustable screw so you can adjust the clutch pedal travel at the up end. If you have access to a Ford or I.T. manual you can see the clutch arm with the stop screw. We welded it this evening with a cast iron rod and also added a re-enforcement to. Hope it holds. Thank
