TractorLinks.com
Order Ford 3000 Parts Online
Re: ford 3000 clutch release lever
Ultradog MN
10-20-2012 05:40:28
I doubt it is cast iron. More likely cast steel which welds easily. If it was cast iron you could still braze it - in place.
kermit vetter
10-20-2012 14:32:21
 Re: ford 3000 clutch release lever in reply to Ultradog MN, 10-20-2012 05:40:28
I know cast iron when I see it. I've been welding for 60+ yrs and my brother even well before that.
I've welded everything from armor plating to stainless in my military career. I've welded many a cast iron bell crank on APC's (armored Personal carriers) and I used a nickel alloy rod. Cast iron rods didn't work to well. I've done a lot brazing too, but its not as strong as it should be.
Fordfarmer
10-20-2012 07:27:23
I'll second that. The shaft is steel, and it's welded to the shaft...
kermit vetter
10-20-2012 14:35:23
 Re: ford 3000 clutch release lever in reply to Fordfarmer, 10-20-2012 07:27:23
Yes, I know the shaft is steel, but the arm attached to it is cast iron. This arm also has a set screw to adjust the arm travel.
RickB
10-21-2012 03:03:34
 Re: ford 3000 clutch release lever in reply to kermit vetter, 10-20-2012 14:35:23
"Yes, I know the shaft is steel, but the arm attached to it is cast iron."
There's only one version of that clutch shaft with the setscrew stop adjustment. I had one of those welded a couple months back and the professional, trained welder that did the work told me that the arm was cast steel, and it welded easily and well for him. His work looked very, very nice. Based on that input, and that of others here, I'll tell you that the arm is cast steel.
Fordfarmer
10-20-2012 15:10:00
Since yours has the setscrew, you have the double clutch for live PTO. The picutre Ultradog posted is of a 6-speed, non-live PTO model.
Ultradog MN
10-20-2012 16:38:49
 Re: ford 3000 clutch release lever in reply to Fordfarmer, 10-20-2012 15:10:00
Mark, you are correct the first photo I posted is a 6 sp non live pto.
I'm curious...
Did you remember my junk or were you able to tell from the pic? If so tell why please.
The photo below is a 3600 with lpto. You can see the arm/bell crank is different. Both however are welded onto the shaft.
Kermit, can you post a photo of it?
If the arm was welded onto the shaft then it surely can be rewelded if broken.
Check Break offered good advice too below. Make one.
Fordfarmer
10-21-2012 00:26:28
 Re: ford 3000 clutch release lever in reply to Ultradog MN, 10-20-2012 16:38:49
I saw the tractor dolly, so I figured it was a close-up of the 2000 you're working on. (should try to talk my uncle into buying it... good trade up from his 8N) One of the 3000's I had used the arm with the setscrew, can't remember about the other one. The arm on my 4600's clutch (independant PTO)is similar, but not identical to these... and is cast steel.
kermit vetter
10-20-2012 18:23:30
I wished I could send you a pic. of it. This is a 1965 3000, 8 sp trans with LPTO. On your pic. you see the protrusion in front of the clutch lever that serves as a stop. The lever has an adjustment screw that is adjustable screw so you can adjust the clutch pedal travel at the up end. If you have access to a Ford or I.T. manual you can see the clutch arm with the stop screw. We welded it this evening with a cast iron rod and also added a re-enforcement to. Hope it holds. Thank
