Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Oil Additives
Ga Guy
10-19-2012 11:36:54
Sounds good. I will try the thicker oil. I already run low rpms. Maybe it will help. For sure there will be no rebuild until it gets much worse. At 50 hours a year it should last a good while longer. I will hold off on the "snake oil" for a while.
10-19-2012 16:58:32
 Re: Oil Additives in reply to Ga Guy, 10-19-2012 11:36:54
what oil do you use now?
if a 10-30 I'd go to a 15w40
or.. just add oil at 10 hrs.... if you use it 50hrs a year.. that's 5 quarts...
5qts a year is an oil change.
slap a new filter on it each year and you got a continual oil change going.. :)
walmart quarts of oil are less then 3$ or gallons are less than 13$
Ga Guy
10-20-2012 02:36:35
 Re: Oil Additives in reply to soundguy, 10-19-2012 16:58:32
I have been using the 10-30 so I will change to a heavier weight. Living in the South with the warmer temps should allow me to do that anyway. Thanks and I will go with what ever it does until it gets much worse.
10-20-2012 13:53:41
 Re: Oil Additives in reply to Ga Guy, 10-20-2012 02:36:35
i run a 15w40 c rated oil in all mine but 3 now. one gets a 10-30 syn after a parial rebuild.. and the 2 others are diesels getting 5w40 syn.
I believe your consumption issues will significantly taper with 15w40.
my wifes 2000 yukon/5.3l will guzzle 5w30, and gulp 10w30, but only sips 15w40.. :)
