Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
oil pressure line
WILBER
10-18-2012 14:44:29
ON A 134 NAA MOTOR WERE IS THE OIL PRESSURE LINE HOOKED TO THE BLOCK
WILBER
10-22-2012 04:19:15
 Re: oil pressure line in reply to WILBER, 10-18-2012 14:44:29
Royse i want to thank you for the picture it is worth a thousand words.
Royse
10-21-2012 19:13:09
 Re: oil pressure line in reply to Fordfarmer, 10-18-2012 14:44:29
Wilber, here's a picture of the oil line running in behind the pump on my old NAA.
Behind the red coil wire.
You can find it without taking the pump off, but it is hard to work on with the pump in the way.
PS, please turn the caps lock off. Its hard for me to read that way.
WILBER
10-19-2012 05:23:05
THANK YOU I WILL TAKE A LOOK WHEN I GET HOME WILBER
soundguy
10-19-2012 17:19:37
 Re: oil pressure line in reply to WILBER, 10-19-2012 05:23:05
post back if ya got any more ?'s
wilber
10-21-2012 15:42:54
 Re: oil pressure line in reply to soundguy, 10-19-2012 17:19:37
DO YOU HAVE TO TAKE OFF THE HYD PUMP TO FIND THE MOTOR OIL PORT? AND IS THE FITTING SOMETHING SPECIAL.
soundguy
10-22-2012 04:56:56
 Re: oil pressure line in reply to wilber, 10-21-2012 15:42:54
the pump does not have to come off to find it.. you will almost assuredly have to take it off if you have to do much, other than unioninga line to a stub or something.
not to especially difficult..
soundguy
10-18-2012 15:24:34
yep.. look for a lil elbow with a 1/8" cap line behinf the gear drive portion of the engine mounted hyd pump on the right rear of the engine, as Kurt mentioned.
Kurt-NEPA
10-18-2012 15:05:08
If you are talking about the oil pressure line to the pressure gauge, then it connects to the block behind the hydraulic pump. Kinda hard to see with the pump in place.
