| Author |
[Modern View]
| Terry Wible
10-18-2012 14:07:16
67.234.36.159
I'm sure there are people out there that have a way to paint the raised Ford lettering on the sides of the hood. Can I hear suggestions? Thanks, Terry |
| ramtuff
10-19-2012 15:27:07
98.93.145.83
Re: Ford 660 how to paint Ford raised lettering. in reply to Terry Wible, 10-18-2012 14:07:16
| I always use a Q-tip, works good for me. |
| Cliff(VA)
10-19-2012 07:09:26
70.89.233.37
| | I do not think that most people are satisfied with either the stencils or vinyl letters. If you have a steady hand, painting with a "pin striping brush" works pretty well. A pin striping brush has very long bristles that allow you to lay down a controlled width, straight line of paint. There is another way that you will find in the archives. It basically amounts to painting the stencil area FIRST with a number of coats of red paint to get a thick layer. Then paint over with the grey. After the grey has set up you use a sanding block with 400 grit wet or dry sandpaper to sand through the grey to the red. If your sanding is better than your painting I would try this method. HTH Cliff(VA) |
| Terry Wible
10-19-2012 07:01:28
67.234.3.140
| Thank you all for your replies. You have been very helpful. I will ponder the different ideas. |
| JDseller
10-19-2012 00:20:02
208.126.196.144
| How we always used to do them was a tee shirt over a wooden block. Just wet the shirt with paint and use it like an ink blotter. |
| showcrop
10-18-2012 18:51:27
75.67.231.80
| Or you could buy the script vinyl letters on ebay |
| GlenIdaho
10-18-2012 18:33:38
65.129.65.162
| | Here's another idea. You can take some tracing paper and trace the raised letters then go to a sign shop and have them make a stencil using self-adhesive vinyl. Put it on as a stencil and then paint. It would be easier to separate the letters when putting it on. You can go to an auto paint store and buy some vinyl tape used for pinstripping to cover any gaps where the letters come together. I used the pin stripping tape and carefully taped around each letter, then painted. A lot of work but it worked well. Good smooth edges. When applying vinyl tape be sure to press the edges down. I have two fenders to do and I'm going to prime them, apply several coats of the red, apply a mask and then paint the gray. I tried painting with a brush but was not happy. I was using Omni MTK. |
| Royse
10-18-2012 18:26:27
69.36.49.151
Re: Ford 660 how to paint Ford raised lettering. in reply to crm88, 10-18-2012 14:07:16
| Terry Wible said: (quoted from post at 20:58:32 10/18/12) I'm surprised that there isn't a decal, stencil, or something aftermarket. |
There is. You can buy them to spray paint over.
I've never used them, but I would be afraid they would lift and you'd get
over-spray unless you used the stencil and then brushed or rolled over it.
Edit - here's and example. fleabay
This post was edited by Royse at 18:30:17 10/18/12. |
| LeoinMI
10-18-2012 17:25:38
75.134.126.44
| I used an artist brush and painted three thin coats to get the correct coverage. |
| Terry Wible
10-18-2012 17:58:32
67.234.36.159
Re: Ford 660 how to paint Ford raised lettering. in reply to LeoinMI, 10-18-2012 17:25:38
| showcrop
10-18-2012 16:49:49
75.67.231.80
| I did the separate sides lying downbefore putting them together. less chance of run that way. I poured a small amount into a small container so that it would thicken a little. Then I went at it with a soft bristle brush. |
| awhtx
10-18-2012 16:24:51
70.196.10.204
| Someone once posted here that the factory rolled it on with a long, curved ink blotter type tool. |
| soundguy
10-18-2012 15:28:28
184.247.51.44
| | i hand painted mine with a detail brush. I hear some use a foam roller... |
| Kurt-NEPA
10-18-2012 15:07:42
70.44.245.96
| I just painted mine on my 660 with a fine brush. Used Valspar paint and hardener. Might not be perfect, but it looks good from 10 feet away. |
| Daniel Robertson
10-18-2012 19:19:02
98.223.249.230
Re: Ford 660 how to paint Ford raised lettering. in reply to Kurt-NEPA, 10-18-2012 15:07:42
|   I have both the decals to go on the FORD letters, and also the stencels to allow painting over. I chose to use neither of them. Every Ford tractor I have observed at shows that had the decals installed, or had been painted using the stencels left something to be desired to consider it a quality job. Therefore I lovingly sweet talked my wife into painting the letters with her pro-like steady hand. Only requirement from her was to be able to paint them before they were installed on the tractor. she used my flat welding table. I was very pleased with the outcome. Dan Robertson |
| 36 coupe
10-20-2012 04:21:08
66.186.169.176
Re: Ford 660 how to paint Ford raised lettering. in reply to Daniel Robertson, 10-18-2012 19:19:02
| Women do much better at fine detailed work.I made hobby horses for the grand children.My wife did all the paint work. |
