TractorLinks.com
Order Ford NAA Parts Online
Re: Smoking Naa with Very Good Compression
ericlb
10-18-2012 07:52:01
does squirting a little oil into the cylinder before putting the compression gauge on it change the readings? if it does significantly, it probably has worn rings, if not there is another issue going on and will need further investigation, pull the valve cover off and see what the top of the head looks like, clean ect or nasty causing oil to not drain back down to the pan and probably fouling the valve guides
