Had trouble with gas shooting out of gas tank when releasing
gas cap about 2 feet. It made old gas tank leak so replaced
with after market tank. I raised gas tank up as high as I could
get it then had trouble with starting tractor, which then needs
cranked several times before starting. Didn"t have this issue
before changing tank. Took gas line loose from inline fuel filter
and the gas is getting to the fuel filter. Sometimes the fuel filter
will be about half full and if you run tractor it empties fuel filter.
Checked the spark plugs which were black with carbon, which
cleaned and gapped them and the tractor is still hard to get
started. Any suggestions?
