19-525 loader pump specs
Just wondering if anyone knows what pump would
have came with this loader? Its an engine driven
pump on a 5000. I'd like to find the specs on
this pump, psi, gpm. Thanx
I can not say for sure but can say this. Both loaders I have use a vicker vane pump that are a 2500psi pump as 8gpm. On a loader if the GPM is to high you run the risk of flipping the machine due to the lift moving way to fast. Believe me if you ever see the front of a tractor leave the ground from a pump being to fast you would not want to be on that machine when it happens
