Order Ford 600 Parts Online
engine diffs? 78 3600 vs 74 3000
10-13-2012 19:48:43
got a 74 block, sleeved and ready to build. Head from motor is freshened. Both block and head are the same as 78 3600, right?
Shaun Wallace
10-14-2012 18:55:58
 Re: engine diffs? 78 3600 vs 74 3000 in reply to AlanBarrett, 10-13-2012 19:48:43
Yep, Ultra is rite. Back in 75 or so at a Ford service school in Grandview Mo they told us the round/oval intake has better flow than square did.
10-14-2012 07:41:07
 Re: engine diffs? 78 3600 vs 74 3000 in reply to Bern, 10-13-2012 19:48:43
Which head is better?
Ultradog MN
10-14-2012 16:57:49
 Re: engine diffs? 78 3600 vs 74 3000 in reply to AlanBarrett, 10-14-2012 07:41:07
Dunno if one is better.
IMO newer is usually better when it comes to Ford tractors.
Here's a theory:
The 3600 with the oval holes might be because the bigger tractors of that era were all getting turboed. They were a modular engine - 3,4,6 cylinder. Most of the internal components were shared between all three sizes. As I suppose were casting cores.
Others here could tell you more about the big Fords and why they made the changes.
By the way, did they ever turbo a 201?
10-15-2012 07:32:50
 Re: engine diffs? 78 3600 vs 74 3000 in reply to Ultradog MN, 10-14-2012 16:57:49
AFAIK, no, not from the factory. But I think I remember seeing a video of a turboed 4000SU or 4600SU. Ford did offer a turboed 192 (?) for a couple years, so parts from that should fit a 201.
Ultradog MN
10-14-2012 05:12:05
Block and head are basically the same and will interchange - 3000/3600.
The heads are slightly different so you will need to use the correct intake manifold. Other than that you'll find no surprises.
