Yesterday's Tractor Co.
Shop Now View Cart
Order Ford 2810 Parts Online
Re: 2810 PTO
Sean in PA
10-12-2012 11:53:07
I assume that you have the live PTO with the double clutch, and not the independent PTO? Sounds like the PTO clutch is stuck. You could try blocking the clutch pedal all of the way down for a couple of days to see if it frees up. Otherwise you may need to split the tractor and see what's up with the clutch.
If you need to mow now, you could try engaging the PTO lever with the engine off and then start the engine. That should spin it up a little slower than jamming the lever in when it's running. Start the engine with the PTO disengaged first and raise the 3 point arms, and then shut it off and engage the PTO lever and then start it up.
10-12-2012 14:41:03
 Re: 2810 PTO in reply to Sean in PA, 10-12-2012 11:53:07
The 2810 has IPTO, not live.
