TractorLinks.com
Show Parts for Model:
Re: part No for hollow bolt that holds sediment bowl to carb?
Dean
10-12-2012 09:31:40
The banjo bolt is CNH only.
Dean
William Fissell
10-12-2012 09:41:58
 Re: part No for hollow bolt that holds sediment bowl to carb? in reply to Dean, 10-12-2012 09:31:40
thx. Banjo?
RickB
10-12-2012 14:43:30
 Re: part No for hollow bolt that holds sediment bowl to carb? in reply to William Fissell, 10-12-2012 09:41:58
Most fittings that banjo bolts fit through resembles the musical instrument. Doesn't necessarily apply to this application.
6t6cuda
10-12-2012 10:00:52
Banjo is a common name for this type of bolt.
They are used on brakes as well, so (not sure) it might be worth looking at the "help" section of your local autoparts store - they may not be long enough.
It should be easy enough to make if you had to. Just remember to start with a grade 2 bolt or you will have fun trying to drill it...
