TractorLinks.com
Show Parts for Model:
Re: Position control not working
6t6cuda
10-11-2012 18:25:24
sorry, it has been a while and a lot of "other" stuff going on (trying to build a garage).
Yes it is a lever not a knob...
It does hold two positions but they are about 30 degrees apart, one is parallel to the lift plate and the other one is about 30 degrees up. both positions appear to do the same thing when lifting an implement. From the manual it appears that they should be at a right angle for the two positions.
Is there a good test to tell if it is in draft vs. position when just lifting an implement? - I understand when plowing it will act different
Still learning a lot!
