TractorLinks.com
Show Parts for Model:
Ford 8340 ?????
Heavyduty1
10-11-2012 13:44:31
Going to look at a 8340 with cab for sale. It has the 16spd trans and the owner says the tractor will not go into reverse or neutral. The owner thinks that the synchronizers are worn out. If I had to split it and replace the synchro's, what's a good estimate for this type of repair?
Heavyduty1
10-16-2012 15:57:39
 Re: Ford 8340 ????? in reply to Dean, 10-11-2012 13:44:31
Thanks for the info Brain. I'll see what's goin on. 8)
Brian Allen
10-16-2012 15:24:03
 Re: Ford 8340 ????? in reply to Heavyduty1, 10-11-2012 13:44:31
Heavyduty1
I buy mine from "fleabay", I've had good luck - so far!
Brian
Heavyduty1
10-16-2012 12:26:57
Anyone have a tech manual that they would recommend me to buy for this 8340?
Heavyduty1
10-12-2012 11:15:08
 Re: Ford 8340 ????? in reply to TimPa, 10-11-2012 13:44:31
That's what I'm hearing about these tractors. Thanks for the info. 8)
RickB
10-12-2012 02:41:05
Depending on the tractor build date, the F/R synchro alone could run either $1200 or $2800. And it is a long ways in and a long ways back out to replace one. Planning on a maladjusted cable and learning you have a failed synchro could lead to buyer's remorse.
Heavyduty1
10-11-2012 19:16:11
 Re: Ford 8340 ????? in reply to souNdguy, 10-11-2012 13:44:31
Thanks for the reply. I plan to check out the 8340 on Friday.
showcrop
10-11-2012 17:57:01
16 speed is SLE with electronic power shift it could be as simple as exterior elec. connections or solenoid.
