Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 7710
ken tudor
10-10-2012 19:54:04
im about ready to get rid of it. i drain the bottm tank an no dirt at all in thr, i never fill the top tank just put 6 to8 gallon at a time in ,i have not adjusted the new pump yet, it sounds an runs good just dn a little on power an i can feel a little miss in high rpm
DavidNZ
10-22-2012 01:40:49
 Re: 7710 in reply to ken tudor, 10-10-2012 19:54:04
Have you checked the injector pump timing? I had a 6600 that ran fine at 1500rpm and was missing at 2100rpm. Adjustment to timing fixed the problem.
RodInNS
10-10-2012 20:55:11
Well... my first course of action would be to FILL the top tank. That will then give you an idea of what kind of fuel flow is available at the filter and will provide supply enough to rule out a bad lift pump or some minor air leaks in the suction lines.
You can approach this from a fuel supply issue, atomization (injector) issue or a compression issue...
Rod
