(quoted from post at 09:04:43 10/10/12) OT
Can any one tell me if the 239 CID Flathead V8 100 HP had a side dist or was it a front mount dissy?
They put this engine the 1948 F1 Ford Pick-up.
My Father had one in 1958 that I drove when older. It had 3 speed floor shift which I assume was considered hevy duty? Cannot remember location of dist?
Thanks DOC
1948
CID Bore " Stroke " Comp. HP@RPM Torque@RPM Model
336.7 3.50 4.38 145@ 225 lb-ft@
239.4 3.1875 3.750 6.8:1 100@3600 89A Ford
239.4 3.1875 3.750 6.8:1 100@3600 59A Mercury
The F7 and F8 trucks get a 336.7 cid version of the flathead. The F series trucks get the updated flathead (see the 1949 changes).
Sure sounds like "front of right side cylinder bank", to me.
1949
336.7 3.50 4.38 152@ 265 lb-ft@
255.4 3.1875 4.00 6.8:1 112@3800 CM
239.4 3.1875 3.750 6.8:1 100@3600 98BA
336.7 cid motor in the F7 and the F8 trucks is also available in the Lincoln line. The Lincoln version has increased compression to make more power than the truck motor. Mercury's V8 gets stroked for increased horsepower. There are some major mechanical changes to the flathead this year. The bellhousing is no longer cast as part of the block. The oil pump changes to a shorter, straight cut gear pump for higher oil pressure. The water now runs directly to the back of the block from a larger radiator. There are new valve guides, improved intake and exhaust systems, and locked in connecting rod bearings replacing the older floating bearings. [i:6248ab22d2]The distributor is now a modern design, relocated above the front of the right side cylinder bank amd set up to be shaft and gear driven. [/i:6248ab22d2]The distributor drive on the cam changes from the old slot to a gear drive. The fan pitch, cam, and exhaust are modified to make less noise. (The early-'49 cam is milder than the late-'49 to '51 cam.) The coolant holes in the decks and heads are repositioned for better coolant flow to the rear of the block. The water outlets move to the front of the heads. There are better main caps and stronger main bearing webs. Over-all, there are 21 minor revisions to improve idling, valve and cam wear, and cylinder head stress.
