TractorLinks.com
Show Parts for Model:
Re: no spark on 631
old
10-10-2012 08:00:05
Sounds like you got it wired wrong still. If you can run a hot wire from the battery to the ignition side of the coil and it runs then you know your wiring is wrong. To be wired right you should have the one side of the ignition switch hooked to the map gauge and the other wire going straight to the coil
Larharm
10-10-2012 08:38:36
 Re: no spark on 631 in reply to old, 10-10-2012 08:00:05
will the coil take a direct 6v hook up for test from battery without damage
old
10-10-2012 09:18:35
 Re: no spark on 631 in reply to Larharm, 10-10-2012 08:38:36
YES a 631 uses a round can coil and they are made to handle the full 6 volts of the system. Your tractor is not the old front mount weak square coil that burns out easy. As a matter of fact a round can 6 volt coil will handle 12 volts for a good long time as long as the switch never gets left on with out the engine running so YES you can safely hot wire it
