| Ford Tractors Discussion Forum |
Topic: 600 no Hydraulics
[Return to Forum]
| Author |
[Modern View]
| stanger
10-10-2012 06:25:19
76.8.162.33
Hello,I have a 600 and was using the bush hog and when i was finished the 3pt hitch would not raise as if I lost all Hydraulics. Any ideas as where to start troubleshooting ? I will need a diagram if it is a pump. thank you steve |
[Reply] [No Email] | |
| 36 coupe
10-13-2012 16:10:22
66.186.169.176
Re: 600 no Hydraulics in reply to stanger, 10-10-2012 06:25:19
| If you have a vane pump and are using 134 fluid you can lose lifting power in hot weather.The 600 was designed to use 80 or 90 gear oil.If the lift works when the fluid cools dump the 134 and buy 2 gallons of 80 or 90 mineral gear oil for 15.00. |
| old
10-10-2012 07:26:44
209.86.226.19
| First thing to check is the fluid level. No fluid or very low can burn up a hyd pump and if that happens your talking big $$ to fix/replace it. As for diagrams you need to buy a manual like the Ford I-T FO-20 |
| Sean in PA
10-10-2012 07:07:19
71.224.102.32
| Is the tachometer still working? The hydraulic pump is driven by a gear off of the engine, and the tachometer cable is driven off of a fitting on the hydraulic pump, so if the tach is still working then at least you know that the pump is spinning. If the tach stopped working at the same time that the hydraulics stopped working, then it may be the gears that drive the pump. |
| soundguy
10-10-2012 06:55:19
184.245.134.46
|  here.. holding your hand / doing yer research for ya... |
| soundguy
10-10-2012 06:52:10
184.245.134.46
| | gradually die or all at once? where to start? 1, check hydro oil at the dipstick. if it has oil, then check to see if it will lift with no load. if it will not lift with no load, check pump for prime at the top/front plug on the head. if it has oil there, check under the seat on the option panel, with the plug in it.. check for oil there. ( if you have a remote there.. check to make sure you didn't kick it engaged ) if not engaged.. check to see if remotes work. if they do.. pump and relief are fine.. if oil there under the seat and no remotes, then pull cap on rear and look in for massive leaks from top. if nothing apparrent... pull top cover for a looksee.
no sweat on the diagram.. your service and parts manual have them. ( what? no manual? shame on you! ) get one at the CNh parts site... free..e tc.. post back soundguy |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
