| Ford Tractors Discussion Forum |
Topic: 7710
[Return to Forum]
| Author |
[Modern View]
| ken tudor
10-09-2012 19:28:39
70.194.71.217
will the return lines on top of the fuel injectors make it miss if they leak fuel. i put new pump an injectors an still got little miss when pulling her hard. |
| ken tudor
10-10-2012 19:54:04
70.194.129.223
Re: 7710 in reply to ken tudor, 10-09-2012 19:28:39
| im about ready to get rid of it. i drain the bottm tank an no dirt at all in thr, i never fill the top tank just put 6 to8 gallon at a time in ,i have not adjusted the new pump yet, it sounds an runs good just dn a little on power an i can feel a little miss in high rpm |
| DavidNZ
10-22-2012 01:40:49
116.93.135.173
Re: 7710 in reply to ken tudor, 10-10-2012 19:54:04
| Have you checked the injector pump timing? I had a 6600 that ran fine at 1500rpm and was missing at 2100rpm. Adjustment to timing fixed the problem. |
| RodInNS
10-10-2012 20:55:11
216.118.158.123
| Well... my first course of action would be to FILL the top tank. That will then give you an idea of what kind of fuel flow is available at the filter and will provide supply enough to rule out a bad lift pump or some minor air leaks in the suction lines. You can approach this from a fuel supply issue, atomization (injector) issue or a compression issue...Rod |
| RodInNS
10-10-2012 14:25:46
216.118.158.123
| They can let air in... so yes, could cause problems. Do you know if it's getting an adequate supply of fuel into the pump?Rod |
| Bern
10-10-2012 15:35:24
66.218.202.171
Re: 7710 in reply to RodInNS, 10-10-2012 14:25:46
| | Rod, this is one of those rare occasions where I am going to disagree with you. The leak off lines on top of the injectors return fuel to the tank. Since this line has return fuel in it, a problem with this line should leak fuel externally, not allow air in. Even if air was to somehow get it that line, it should not affect the operation of the fuel system. My comments assume an inline Minimec pump. I'm pretty sure my statement is also true with the CAV DPS rotary pump. |
| RodInNS
10-10-2012 16:17:41
216.118.158.123
Re: 7710 in reply to Bern, 10-10-2012 15:35:24
| In principle I'd agree with you... I'd not rule it out tho. My line of thinking was more that it might allow drainback, but perhaps that's possible anyway.I wish he'd just get someone to look at it instead of throwing more parts at it... In my experience a 77 with the fuel staggers is almost always a dirty filter. If the lift lines leak then they won't start once the top tank is empty.... and usually if mine gets the staggers... it'll work OK for a while or until it's placed under a heavy load, then the missing starts. This could also be a venting issue with the lower tank... a collapsed line between the tanks. A lot of things.... We're only armchair analysts from here. Rod |
| Bern
10-10-2012 18:41:35
66.218.202.171
Re: 7710 in reply to RodInNS, 10-10-2012 16:17:41
| | My experiece on any Ford with two tanks that is starving for fuel has been plugged screens in the bottom tank. I think Ford should have gone with a coarser screen once they went to the glass sediment bowl. Or better yet, nothing at all. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
